Does anyone know how the "tubes" at the front and rear of the frames are constructed?
I'm attempting to install plow brackets with the bolts that hold the alum axle extension housing to the frame. They're 7/16-20 bolts so, I doubt the wall thickness of the "tubes" is enough to accommodate this size thread as it would make this item prohibitively heavy (x2). So, I'm thinking welded construction. Tubing with an end cap welded on for the threaded holes. The bolts were not too tight and I got them all to back out about 2-3 turns and then they begin resisting. I'm thinking crude built up on the ends that protruded thru the threaded holes. I've got em backed out bout 1-1/2 turns and have packed around them with cotton ball are these are pickling in Kroil. I need to remove these with out damaging the holes (too much) so they can hold up to the demand the plow mounts will require.
Thanks!
Thanks!
