Hey guys/gals I've got a 1990 argo vanguard 6x6 , a couple days in a row I was using it in high 20 deg c temps and after 25 to 30 minutes or use on rough terrain a lot of which was in low gear it shut down! the first time I figured it may be fuel as the level was pretty low but the next day I had a full tank and still the same, I left it were she stopped as it was only a 2 min walk from my cabin and the next day she started right up and ran fine for the 15 mins or so it took me to get out, do you think it's maybe an overheating issue? It's a fan cooled machine! I used it all week leading up to it in much cooler temps and it was fine!
1990 vanguard 6x6 overheating maybe?
This is a good place to start. I had to disassemble and clean out the vacuum operated fuel pump on my Vanguard because it had a bunch of crud in it that was keeping the vanes in it from working properly. It also managed to push some of the crud through and into the carb inlet which would completely block it up after 10-15 minutes of riding, until I finally pulled apart and cleaned the pump. Hasn't been an issue since.Originally posted by MXZ500 View PostAnother item to check is your fuel lines and filter. Once my Argo sucked up some crud in the tank and plugged the feeder pipe inside the tank. This caused similar symptoms you described.
Also if it's the Vanguard engine, I'm fairly certain that they have a pressure switch that kills ignition spark if the oil pressure drops, so make sure you keep an eye on the oil level.
