Heat!
  • Heat!
    This has been gone over quite a few times, but once again here we go!
    I was originally going to use anoil cooler & blower to heat the passenger compartment. I did all the research I could. What i found out was the oil flow through a cooler is moving at a verry slow GPM. Back to the drawing board.
    Some of you know I'm an old VW nut. I was standing over my bigfoot today trying to figure out a way to pipe in some heat, and bam! VW style heat! Use that hot exhaust for something!
    Here's what i came up with! I will tap into the brake fan with a 2" hose outlet. I'll use a peice of VW flex hose (it's 2" ID) to vent it from the blower to the heater pipe. (Heater pipe will be a peice of 2" OD exhaust pipe with a 90* bend) I'll place another flex hose from the heater pipe to the dash.
    The heater pipe will be roughly be 20" long running across the muffler heat sheild, front to back. There will be a 90* bend, and roughly another 8-10" of pipe pointing twards the drivers side at about a 20* downward angle. The heater pipe needs to be welded to teh muffler heat sheild, roughly 1" from the edge of the engine compartment, and you may need to add some automotive heat sheild padding on the bottom of the hood to protect it against the heat! This should be plenty long enugh to let the heat of the muffler transfer to the heater tube. I may eventually add some sort of restriction to the dash end of the tube to slow down the flow, and get adequate heat.
    Now for my problem!!!!
    What can i use as a vent on teh dash? I prefer somthing that can be closed for warmer days, and in some way adjustable to point up for defrost!
    Jeff
    02 Argo Bigfoot
    My first thought would be to salvage a vent or maybe two out of the dash of a junked vehicle. JCWhitney probably sells universal vents too, I haven't looked for them but that seems like the kind of thing they would carry.
    Attex Super Chief - Sold.
      Yes, I agree.
      My suggestion:
      Try a set of side vents from a Porsche 914 (I'm an old Porsche/VW guy too ) They are already designed to accept the hose! Just cut a rectangle in where you want to mount it, push in the vent and hook up the hose!
      Just found these on Ebay... you can get them for MUCH cheaper though...
      eBay Motors: 1973 Porsche 914 1.7 HEATER AIR VENTS RIGHT & LEFT (item 320272214926 end time Dec-05-08 10:11:33 PST)
      Hope this helps!
      ---JIM---
      I reject your reality and substitute my own...
      (Mythbusters Fan )
        Thanks! I'm only concerned with the size of the vent& how it will fit the dash. Once i cut the hole, there's no going back!
        Jeff
        02 Argo Bigfoot
          Tory made a heater for his Argo. Here are some pics.
            I thought about putting some vents in that spot, but I'm primarily interested in the defrost effect on the windshield! I may just have to break down and fab. somthing! Guess it's off to lowes & the junk yard I go!
            Jeff
            02 Argo Bigfoot
              I have worked at a few parts stores that have carried these units. They do however draw alot of AMPS. But the install would be alot easier.
              BACK SEAT HEAT PLUS
              12v Direct Wired Back Seat Heater Auto, Truck, RV, Boat Heater. With Thermostat and Fan speed adjustments. Heats those always cold areas in Autos, RVs, vans, boats, trailers, cabs - virtually any vehicle - with this powerful compact heater that heats up instantly; provides over 1100 BTUs of heat. Comes with all the necessary wiring, optional dash mounted switch and universal mounting bracket. Hard wires directly to battery. dimensions 5" x 6" x 3" 300 watts, 25 amps at 12vdc - 600 watts, 25 amps at 24vdc 1100 BTU's of heat for 300 w, 2100 BTU's for 600 w weight: 8.5 oz Heat or fan feature adjustable fan speed 20' power cord adjustable thermostat all installation hardware included fan 102 CFM 2 year warranty Made in USA, this is not a cheap Asian copy.
              If it looks like you can't make it, you probably can't, but what the hell you can call in sick tomorrow......right?
                BACK SEAT HEAT PLUS
                Thanks for the idea! I hadone in an old POS I drove in highschool, and it's great for heat, but the room it takes up is valuable in a 6x6.
                Jeff
                02 Argo Bigfoot
                  Maybe mount that somewhere in the engine compartment and build a duct that will funnel it into the VW hoses...
                  Just a thought...
                  ---JIM---
                  (Mythbusters Fan )
                    golf cart heater
                    Just a thought, but I believe they make small heaters for golf carts that run on the small propane tanks. They would be portable and easy to install. I plan on looking for one to put in my hustler.
                    I don't want to go fast, I just want to go anywhere.
                      Open heat in a POLLY body is bad news!
                      These may be just what I'm looking for! I gotta get the measurments on the vents, but looking promising!
                      Jeff
                      02 Argo Bigfoot
