I just purchased an Argo Aurora 800, and I'm having trouble figuring out all of the maintenance.
Grease. I know this thing has a ton of grease zerks. Anybody know specifically how many? The manual mentions specific grease (i.e. lithium) for some, but doesn't specify for others. Do I use different greases in different places? All synthetic marine? How often (every 10 hours?). Specific grease recommendations - Amsoil? SuperLube? Other. A lot of the manual mentions Argo specific lubes, but I can't seem to find them in stock anywhere. Also seems that mixing greases may be a no no. Any idea what kinds of grease is where now? How much grease? I have a hand greaser, but is there much risk of blowing out seals with too much grease? Seems some things that get greased are okay with too much, but others its a problem and you'll destroy seals. I seem to see 1 to 2 squeezes per zerk. Sound right?
Chain Oil. I know it needs to be water proof/resistant, and low sling. Bel Ray Super Clean Lube looks to be the best option - can anyone confirm or refute? I've seen ChainWax mentioned, but it seems to not be real penetrative (there is multi-bundle with a 3 step process - clean, lube, wax). Dupont Chainsaver has been mentioned, but I get the impression it doesn't hold up real well to water and needs near constant reapplication. How much? Just coat it? How often? Every time you ride? 10 hours?
Sparkplugs - I have the Kohler 30HP. Factory plugs are champions. In the past dealing with motorcycles - seems like there was a benefit to swapping to fancy plugs - NGK, Bosch, split-fire, etc. Is there any reason to replace the Champions prior to end of life?
I will have the dealership do the 20 hour break-in service - oil change & transmission fluid change (anything that needs to be retorqued), but I will likely handle it afterward. It's a bout a 2.5 hour drive, so I'd rather not rely on them for too much.
I've read the bolts at the wheel bearings need to be retightened after a few hours of service or you get leaks around the cork seals. Does a cork seal seem like a bad idea, or am I missing something? Wouldn't rubber have been better?
Chains seem to adjust tension themselves. Anything I need to do here?
Anything that I need to do with the brakes on a regular basis?
Anything else i should be doing on a regular basis - besides just checking fluid levels - oiling chains and greasing all the zerks?
Also how likely is this thing to tip in water? I've had it in water and it feels somewhat tippy with passengers moving around, but I don't have a good sense of its limits.
How often do these things get holes in the tubs? Does flexseal or jbweld work as a field repair?
What tools do you all routinely keep on the machine? Obviously an allen to get to everything, and a basic tool kit - sockets, wrenches, screwdriver. I haven't even looked is it all SAE, or is there metric as well? Any special tools? Any odd or common sizes? I have ordered the specific vice grips for putting on chain master-links, and I bought a low pressure tire gauge. I have a boat hook that can be used as a push pole, and I have a couple extendable paddles on order. Will add a bail bucket. Anything else? Anybody use an anchor? I assume some sort of tie off would be useful.
Any high failure items to keep on hand such as belts?
Anything else I should know?
Sorry I have a lot of questions. Shanks and ArgoAdventure both seem to have lots of good info on these machines. Any other good sources I should look at? I'm making my way through threads on this board, but I haven't found all the "good" stuff yet - any direction would be appreciated. Thanks in advance.
