So i picked up an 05 argo avenger with the aegis lh775 efi engine. The PO told me that the machine would not run and that he installed a new fuel pump. The po stated he got the machine and never had it running. The machine would run using starter fluid.
Low and behold the fuel pressure at the rail is only 5psi. The machine needs 39 +/- 3 to run correctly.
I either need to find a fuel pump and fuel pressure regulator from and argo or i can adapt a high pressure pump and use an adjustable furl pressure regulator and turn it to the required 39 psi. Thoughts please
