Hi folks,
I am hoping someone might be able to point me in the right direction on my frontier scout. Since the scout doesn’t come with high beams, I installed a light bar which I wired to the high beam wiring, with use of a relay (same automotive style that you would use of installing HIDs). My scout was missing the relay in the relay/fuse box, so I added that as well. My issue is that once I turn the lights on(low beams) the high beam indicator on the display and the light bar come on. I have tried disconnecting my setup, but as long as the high beam relay is in, both circuits are on. It’s almost like my multiposition switch is simply shorted out and doesn’t actually have a separate switch for the high beams.
Any ideas?
Any ideas?
