The right side idler chain on my 2008 Avenger has too much slack, but when I do the prescribed adjustment procedure both the right and left chains adjust at the same time. If the left chain has the recommended 1/8” slack the right one is way too loose. If I tighten the right side the left is too tight.
Is it possible the right chain has stretched more than the left? Can you adjust the two sides separately?
