I am trying to remove the primary clutch from a 1991 Vanguard with a 16 hp opposed engine. All i can find is that I need to remove the bolt holding the clutch to the pto shaft. There is no bolt. Is the clutch screwed on to the shaft like the early Skidoo Rotax engines? If so is there a tool to remove said clutch or will I have to make one?
clutch removal.
