I thought that Argo fixed the 3 wheel drive problem with the admiral transmission. I have a 2020 Aurora 950 and today I was going up a hill with some ice on it. I was going slow because I wanted to spin to check this out. One side just spun and until I applied some brake then the other side spun. With the bars straight only one side would spin.
3 wheel drive
I have the same problem with my 2021 6x6. With handlebars straight 3 wheels on one side move. I have to keep bars turned slightly to have 6 wd, I also noticed if I hit brake lever it would engage 6 wd. I guess these Argos have quirks . This is my first one. Not sure if theirs any solution
I have seen Admiral transmissions do this on occasion, I not sure why, seems that sometimes they don't seem to work as planned, for what ever reason some times you have you have to rapidly move the handle bar back and forth, I am not sure exactly what this does but after that it will generally straighten itself out. I have never seen an Admiral do this in the mud, only in limited traction situations.Originally posted by Mtgladiator View PostI thought that Argo fixed the 3 wheel drive problem with the admiral transmission. I have a 2020 Aurora 950 and today I was going up a hill with some ice on it. I was going slow because I wanted to spin to check this out. One side just spun and until I applied some brake then the other side spun. With the bars straight only one side would spin.
. I’m enjoying turtling around with this thing. It’s pretty cool. Good luck
