I’ve been browsing the forums a bit, and found the answers to some of my questions. However, I have a ton more and am also a little frustrated. I bought this Argo about a month ago, but it seems to have little things I’m not happy with and am considering selling it and saving for a newer one. Buuuuutttt... If the work is worth it to hang onto the machine and save myself some $$$ then that’s what I’ll try. I have also watched some of the videos that RockDoctor has on YouTube to get tips.
For reference this is what I paid and what I got.
- $7,500 (CDN)
- 2003 Argo 8x8 Conquest
- 20hp Kawasaki motor
- Plastic tracks with metal cleats
- machine has 955hours
- heater
- windshield with the borderline useless hand wiper
- canvas top (couple rips and tears but in decent shape for the age)
- numerous bearings replaced (8 I believe)
- no bilge pump (no biggie as they are inexpensive)
I also have yet to run it with the tracks off in summer as I bought it in January and I’ve only run it in snow so that may affect my experience thus far.
Questions:
1- I’m a little underwhelmed by the power of the 20hp motor, would it be worth seeing about an engine swap?
2- What is the red light to the left of the choke? When the temp gauge hits 180+ Fahrenheit this will sometimes flicker. Is it a warning light for overheating? I already replaced 1 rad hose that ran to the heater because I was certain it was leaking. And I plan on doing a rad flush soon in case scale buildup is a problem. The Argo has shut off on me on the trail once or twice when this light started flickering so that’s why I thought it may be an overheating issues.
3- When the Argo is in reverse she screams. And it’s instantly once it’s moving. I’m worried I’m going to break something and my kids whince when they see me shift to reverse. Any idea what this is?
4- She can’t power the winch. I’ve had to use the winch 3 times now and it’s an awesome affair. After running it for a bit it was just stop working and I have to turn the Argo off then on again. From what I’ve read there’s a stator and not an actual alternator. I would like to add more accessories onto the machine, but am concerned if there’s not enough power. Recommendations?
5- I’ve been racking my brain where to mount the new bilge pump. I’m assuming on the side where the belt drive is because that’s where the outlet hole is, but can’t find the original bracket.
6- Can anyone recommend if there is somewhere I can get a thumb/trigger throttle. The twist throttle is not great and my wife hates it.
7- I’m not super mechanical, enough to be dangerous and willing to try something, but prefer guidance and direction or a knowledgeable mentor while doing the project. I believe the belt drive front clutch is rattling, but not certain. As my experience is with snowmobiles for these drives, a rattle is bad to me. Is there anything I can check or tighten to trouble shoot this?
Hopefully I haven’t blasted out too much rookie spiel. Appreciate any and all guidance available. Thanks
- $7,500 (CDN)
- heater
Questions:
