Tire pressure with tracks
  • Tire pressure with tracks
    I have searched best I can for tire pressure for my 2017 frontier S 8X8 with tracks. I know very little about these. Downloaded the service manual and watched many videos online. I don't have a clue the brand of track. They are rubber and the guides are a hard rubber. What other info is needed? I have only had it for 6 days so I don't know much about upkeep on it.
    Right or wrong I run 3Lbs in my Aurora tires with the Argo rubber tracks and that seems to work well.
      My manual says 5,7,7,6 front to back. I run with these and it seems to work. Tire pressure also affects track tension. Too little, especially in the front, and the tracks slip on the tires and tend to come off or go crooked on extreme grades. Too much tension is hard on the bearings so make sure your tracks hang down 2 to 3” in the middle when you jack up that side. Take air out of the back tire first if the track is too tight. Good luck!
        Thank you for the info
