Hello, all! I have a 2005 avenger that makes a very irritating grinding noise when I put it in reverse, and hold the handlebar back on the right. I've taken off the firewall, and watched it as I do it, and can't see anything that would cause the issue
. Note, it doesn't do it in any other scenario, ie; forward turning or reverse holding the steering to the left. Also note that the left-side drive chain is slightly loose, but this has never affected it before.
Any help would be appreciated.
Argojim, I'm counting on your guru wisdom!!
Thanks for all your advice, guru!
