Last night I was riding, and shut of the Argo to talk with friends. It wouldn't restart. I replaced the battery, and still just a quick sound. I though the starter, so ordered another one. Now, I just looked under the hood, and the whole motor is crooked, and a motor mount stud is on the bottom of the hull. My Argo mechanic died just a few weeks ago. There is a dealership about 30 miles from me, and I hope they can do huge repairs. I think this is way beyond my skill level.
Broken motor mount
If the engine shifted out of position then you may have more than one broken bolt. Like maybe three... with one holding on, or just some very loose ones. Grab the engine and twist it till the belt lines up. With a good light look down to the bottom of the engine corners and see if you can find some bolt heads or holes. Most of these things can be a regular pri*k to work on. You may have to remove some stuff, maybe not, to get to the mounting bolt area. When you get there find a good bolt or the broken halves to find out what size. If you get that far I would then get 4 new grade 8 bolts and nylock nuts. Put them in the holes and tighten. If you are the type of person who enjoys a cold beverage of the malt extraction, you may want at least a 6 pack. Maybe more if you decide to encourage a buddy to help. Tell him or her it's not a job.....it's an adventure.
my buddy had the same thing happen to him,stud broke off engine turned sideways the oil filter got chewed up by the seconday clutch.they had to remove the engine and drill out the broken stud,damn things are welded in at bottom of engine mount frame.this was apparently caused by incorrect torqueing specs from the factory.i swear to god when you buy an argo you got to disasemble the whole machine then put it back together properly.i did that to mine a year ago,now i can ride with a little more confidence.
Thank you for the information. I know that when I first got my Argo, the electrical system was horrible. I rewired everything. I have had my previous Argo mechanic, now deceased, replace the alternator. I have replaced a belt on the alternator and that was a nightmare because I couldn't get a tool on the lower bolt to hold it while I tightened the other side. I really didn't think that I would lose my Argo mechanic, and be faced with removing the engine, but that is where I am. I never expected that the whole engine would come loose.
There was a short run of 17s that the engine mounting studs were not correctly torqued.sigpic
Finally, some good news. I vacuumed out the radiator, since it was exposed, and shoved the engine back into position. It actually started, and I was able to drive it into the trailer. I thought I was going to need help pushing it in, but it drove right in. Friday, it's going to be really hot outside, so I might wait until Saturday to drive it to the repair shop. It's a little less than 2 hours away, and might stress the Jeep pulling that much weight on a hot day.
