I got my 6x6 and it runs great the thing has a lot more power then I thought it would with a 16hp motor. The one problem I'm having is shifting into gear the gears really grind when I try to go from high to reverse I mean really grind . am I doing something wrong is there a special way to shift because I don't want to do any damage forcing it into gear. I said it wouldn't be to long after I got it that I would have questions less then a day. I'm going to go over it really good before I try to take it out . I'll make sure every thing is tight and greased and oiled and check all fluids I most likely will change all the fluids even if they look okay that's just the way I am. I have this problem that if I don't do it then I don't know if it was done and done right. If someone can get back to me about the shifting grinding that be great.
Thanks
RJ1.
Thanks
RJ1.
