I know I've only had my Argo for about 6 weeks but I would really like to put a more powerful one in. My machine is a 98 Vanguard 6x6 with the Vanguard 16hp twin cam motor. The reason is not for speed but where I ride there's a lot of hills and my machine has a real hard time with them. What's the best motor that will fit in the place of the one I have now? I'm not looking for anything crazy just a little more power.
Thinking of replacing 16hp motor.
An 18 or 20 are direct bolt ins provided you get the right crankshaft size and higher charging system, the 20 is a 2brl carb. A 23 will fit but exhaust is an issue along with excess heat and possible overheating.sigpic
I upgraded(?) to a Briggs 23 vanguard from a 16 opposed twin Briggs. I too, found the machine slightly underpowered especially with the tracks on. The 23 came out of a skid steer machine which I picked up , in my opinion, economically viable to my budget. The 16 had a screw on clutch, like the early Rotax skidoo engines. The 23 came with a 1 1/8 crankshaft pto so I had to find a clutch to fit the straight shaft anyway. The 16-18 Vanguard and maybe the 20 come with a 1 in pto shaft, to the best of my knowledge. If so then should you go to an 18 or twenty then you will have your clutch. The 23 might come with a 1 in shaft option, don't know. Someone mentioned to me earlier when I came across a 18 Kohler, was 2 hp worth the hassle, so I opted to wait for the 23 hp. It is still a work in progress but I am mobile. A lot of chatter on the 23 overheating so I have added an extra fan, wrapped the exhaust, which as mentioned, you will have to fab up, and have the parts to install a cylinderhead temp gauge. The 18 and 20 I believe bolt right in, the 23 has a different bolt pattern so a mount plate has to made. I stuck with the Briggs because the Vanguard has a good reputation, the parts are realitively cheap and just about every small engine shop is either a Briggs dealer or has parts. I have worked on small engines for a lot of years and have barely scratched the surface of knowledge on them so I am no expert to give advice, just what I have experienced. If it is a piece of mechanical equipment it will break down, usually at the most worst time. If you upgrade to more hp, you may want to consider Kohler, Honda, Kawasaki optons. Different people prefer different brands for a variety of reasons. All are good, all will breakdown sometime, maybe not yours in particular, but the brand in general. You will enjoy the build and wonder at times"What the he## was I thinking." Remember....have fun and stay safe.
Laird. I think your right about going from a 16hp to a 18hp it's not worth it but going up to a 20hp or 23hp would be will worth the work. I was looking for a winter project. I went out on my Argo yesterday and went up a hill I've been on over a hundred times on one of my atv's and never thought anything of it but in the Argo with the 16hp motor I just made it after 3 times trying. Out of all the videos I've watched before I bought my Vangaurd almost all of them where on flat ground and I really don't think these machines were made for hills . But I do have to say I went through this trail we call the pit that eats Side by Sides and ATV with real good mud tires up . I've never made it through with any of my machines before and had to be pulled out a couple of times yesterday I put my tracks back on and did the trail with my Argo and I had no problem once or twice I had to rock it side to side but I made it. The only thing I don't like is its the only machine I have without a wench on it and no one has the mounting bracket I need so I have to try and make something to mount a wench on because I ride by myself a lot and like I said I hate not having the wench to back me up. I would love to meet up with some other 6x6 or 8x8 owners to ride with but I've only seen one in my area once and he wasn't from here he just came to try out the trails and there's no way I can keep up with the guys I ride with on ATV'S and me in the Argo.
The biggest difference between the12,14 and 16 is the carb bore and head chamber designs, they are all480cc, the 18 and 20 are both 570cc with the single barrel and 2 barrel carbs the difference. A 23 is 623cc? However it is wider and slightly taller. I had seen a 23 in a Bigfoot at one time.
Keep in mind, the Vanguard, 2, Bigfoot and response have the lowest clearance in engine compartmentsigpic
Keep in mind, the Vanguard, 2, Bigfoot and response have the lowest clearance in engine compartment other than the pre twins.sigpic
Recently I got the 18hp installed in my V2, it was a direct bolt in using all the old parts needed to make it appear stock. Even with my severely worn drive clutch there was a noticeable difference in performance, the machine had more pull to it.
Would I have done this if I didn't have one or need to pull the engine to change the stator?, probably not, but I do like the difference.
I have had the engine on a shelf for 12 years and did nothing to it but change the oilso adjusting the valves and a tune up may help a little more, but I'm happy.
I will keep the original engine and probably will go back in at some time as the 16 did its job for 22 years and 1140 hours with no issues until I pinched the stator wires replacing the starter drive gear. I pulled some serious hills with 4 people in the machine over the years, you just need to learn the machine to accept how it does it.
If you ever go this route, I would recommend going with the 18 for ease in installation, the 20 would be near as easy with the throttle linkage being the biggest possible variable. Be advised though, the newer engines all come through with sealed carbs for emissions and the 16 carb is smaller than the 18 carb.
Good lucksigpic
