Hello to all, was wondering if anyone has ever used an engine tuner on their Argos to boost HP. I know that many people use them on their own vehicles to accomplish the same task. The brand I saw was Magnumtuning.com. Thanks
Engine tuners
I've always heard that tuning an engine this way gets you a 10% increase in power. Anything more than that could be dangerous to your engine. For an engine in an Argo you are looking at around a 2hp gain. I have never done it to anything. Its just what I've heard. Hope this helps. Let us know if you do it and how it turns out.
hi
Always need to careful tuning particularly a v twin being in a AAtv
transmission temperature
engine temperature
drive line temps
Uneed xtra cooling
bigger carb
10--20degrees more cam
higher compression
improved exhaust
rev limiter
better connecting rods
This will gain u 10hp on a 570cc 18 hp briggs
Western skies Argo developed a turbo for the 750hdi and they produce about 60hp, I know several guys in Alaska that have been running them for a few years and love them. I could be wrong but I'm pretty sure with the exception of some clutching its all bolt on plug and play. They don't necessarily give more speed but keeps your track speed up under loaded conditions like hills , deep snow, heavy loads, marshy areas, ect. , they have a lot more grunt so they don't need to back shift to stay in the power. Nate, AKA Argo whisperer at Allseasons Argo in Anchorage, Alaska has installed quite a few of them and ran them for several years. I road with some of those guys that have them and they just don't run out of power going through the marshy areas.
