Working on a 03 Argo response that has been destroyed. Need rims,axles, ect. Gathering up pieces. I also have 6 26x12x12 tires and rims I can’t use.
2003 response parts
No problem it’s bad but for what I need it for it will be great. I’m going to tear it up any way. I’m glad to have it. The other one should be here the first week of December. My hunting buddy is bringing his 2021 down dec 8. We’re going to see if it will go threw 14’ phragmitis
Jim is there 2 different size axles in this machine and if so do you have them. I just found out tonight my engineer buddy that I hunt with, his son is working in southern Nj and for the last 2 years he has been building axles, and bearings. I’ll find out the name of the shop but I’d like to give him to axles so he can make me all 8.
I'm not sure you have 2 different size axles in there and your not just seeing the bearing extensions.
If you would like to have him make them, have at it.sigpic
Didn’t know if you knew if all the axles are the same or different.I’ve got the machine up on blocks and it starts, and runs great. When in drive the right side drives but the left does not. When you give it gas it moves slower than the right or when you barely pull the right stick back the left side drives. Not sure what that is yet.
Yes axles should be the same with the bearing location being the difference, the differential does that as we spoke about the other day. Your new machine should do the same, your friends machine acts different unless it is in low range.sigpic
