Hi guys.
I'm new to this Argo 8x8 750HDI Kohler engine.
It stopped running a couple of weeks ago with a failed electric fuel pump.
I replaced the pump and inline filter and it ran again but within a day dropped onto 1 cylinder.
I've checked the spark plugs and ignition circuit and the blink diagnostic says its #52 which is electrical short or break to the fuel injector for #2 cylinder.
I also found the 10 amp fuse beside the ecu had blown.
I think the injector code was just the connector at the injector not fully installed but the 10 amp fuse has blown again and the new pump wont activate.No fuel no start.
I get continuity from the injector connector to the relay block but don't know what I should get with the other wire
I tested the relay as OK per the manual.
Why would this 10amp fuse be blowing?
Any helpful suggestions would be welcome.Cheers Colin.
