Hey guys just a quick question I went on a fishing trip with my argo response and when I was climbing a hill the argo was slightly slanted to the right all weight being on that side but the track on the right wouldnt spin but the left was. is that normal ? I figure they should both turn no matter what right ? It's the first argo I own so not sure if it's normal
98 argo response issue
I get this as well. The open differential sends power to the side with the less resistance. Sometimes you can overcome this by steering to the spinning side briefly. This applies the steering brake to that side causing the differential to send power to the other side, the one with the higher traction, and you can regain some forward momentum, albeit with some change of direction.
