Been awhile since i had input to this forum life's challenges sometimes get in the way that aside my olde Avenger came to the end of useable life all the way around i had been amassing parts for years but health held me back finally getting it done the list New engine/clutches/new 3.3 transmission/rotors calipers masters/new chains adjusters latest forged axles all new brgs sprockets the roller is done engine goes in this weekend then trans then new wiring harness and back on with the lid its been a fantastic machine over 4 thousand hrs it was used a ton usually on the ranch daily year round took us fishing way back lakes hauled multiple cargo loads to camp i just felt i owed it now iam sure it will outlast me or so Plotthound tells me.lol Cheers NCT P.S checked the hour meter 4824total hrs
Final Reserection Plotthound Approved
Try this one more time keep loosing my reply thanks guys its a job for sure made substantially tougher with arthritis that now has a grip on me but a couple hours a day forge ahead,before i forget a bud of mine with a couple ish year old avenger had a oil leak it was found to be the crankcase drain plugs 2 were both loose a suction tank always used for oil changes i checked my new engine although not loose far from tight i hope a isolated incident but sure glad i checked mine near impossible to get at the one with a alternator kit as a bracket covers one of them.Cheers Yall NCT
Originally posted by Noel Woods View PostThat's a big accomplishment. It takes alot of work to overhaul these things. 4824 hours so far, that's a testimony to build quality as well. Keep on trucking.
hey NCT,i got your rebuild pictures.cant seem to post them though.not sure what the issue is.theres something screwy with this site.of all the the pictures ive up loaded through the years without issues now i cant.like WTF? no wonder this place is a ghost town.Last edited by plott hound; 09-09-2022, 08:04 PM.
Originally posted by plott hound View Posthey NCT,i got your rebuild pictures.cant seem to post them though.not sure what the issue is.theres something screwy with this site.of all the the pictures ive up loaded through the years without issues now i cant.like WTF? no wonder this place is a ghost town.
NCT glad to hear you're on the path to gallavanting again. 4824 hours is a testament to maintenance and driving abilities.
NCT and Plott, I've found the only way to get a picture up is to text it to myself, either phone or email, as it will resize the photo. Had the same issue with fb as it seams the newer electonics are to good.
Have fun Jimsigpic
Argo Jim question i have always had a alternator kit on my machines and transferred it to the new engine what exactly happens if the Kohler regulator/rectifier that is supplied with the engine was to remain hooked up not that I have ever done this always had it disconnected as per the instructions only time in the past that i ever reconnected it was when i lost a alternator belt back in the boons at that time i disconnected the alternator exciter wire/fuse and also the heavy cable from the alt then reconnected the original stator driven charging system to get me back out.
Originally posted by North Country Tough View PostArgo Jim question i have always had a alternator kit on my machines and transferred it to the new engine what exactly happens if the Kohler regulator/rectifier that is supplied with the engine was to remain hooked up not that I have ever done this always had it disconnected as per the instructions only time in the past that i ever reconnected it was when i lost a alternator belt back in the boons at that time i disconnected the alternator exciter wire/fuse and also the heavy cable from the alt then reconnected the original stator driven charging system to get me back out.
I would assume the one negates the other and one just stops charging.sigpic
