argo magnum engine removal
  • argo magnum engine removal
    trying to remove the engine on my 91 argo magnum 8x8 but cannot get it to move,
    disconected all electrics line etc,
    removed the large mounting bolt that goes throught frame and engine mount and the other one in front of gearbox.still no movement.
    what am i missing ?
    There are three large bolt all together. Front, middle, and back.
      yes see that now,did,nt see that the engine shared the same subframe as the gearbox ,just saw the mount coming down from engine.
      i split drive chains at the gearbox.
      removed gearbox from frame then hoisted engine out with frame attatched.
      argo parts manual made it look like the engine and gearbox had separate mounting frames.what a numpty.used to minis and landrovers!
      now the engine and box is out going to remove all chains clean them. clean tub and frame too
