Hi there.. I have a 2009 Argo avenger 700 that has a factory brush guard and a super winch X2 Winch. The winch is in rough shape and I would like to replace it.. The X2 is no longer available and I would like to replace it with a Warn winch.. Have any of you done this before? If so, what hardware do you need to change on the mount,, and you have to replace the solenoid and switch, or can or can you just use the existing wiring and replace the leads that connect to the Winch? I would like to keep this as simple as possible. Thanks!.
replacing winch
Originally posted by Saucymynx View PostHi there.. I have a 2009 Argo avenger 700 that has a factory brush guard and a super winch X2 Winch. The winch is in rough shape and I would like to replace it.. The X2 is no longer available and I would like to replace it with a Warn winch.. Have any of you done this before? If so, what hardware do you need to change on the mount,, and you have to replace the solenoid and switch, or can or can you just use the existing wiring and replace the leads that connect to the Winch? I would like to keep this as simple as possible. Thanks!.sigpic
Thank you, Jim. That is encouraging. I was looking at it more closely tonight, and it really needs to be replaced. The cables shot, the roller fairlead is shot, at some point in time the cable got out of the fair lead and cut through the housing of the winch, and it just seems under powered. Do you all recommend a 3500 pound winch?
Originally posted by Saucymynx View PostThank you, Jim. That is encouraging. I was looking at it more closely tonight, and it really needs to be replaced. The cables shot, the roller fairlead is shot, at some point in time the cable got out of the fair lead and cut through the housing of the winch, and it just seems under powered. Do you all recommend a 3500 pound winch?sigpic
