does anyone know the order the tires should be on the avenger for tracks. Where does the smallest tires go ect.
Order of tires for Tracks?
kovac, There was a post last year about track and chain wind up that had the order I think. I don't have time this morning to look for it or I would try to find it for you. It's in the argo forum. SethOriginally posted by kovac View Postdoes anyone know the order the tires should be on the avenger for tracks. Where does the smallest tires go ect.
tracks
you will have to set your tire pressure to 7 psi then measure the outside circumfrence of them the smallest goes in front then next size then the largest then remove all air from the tires and install your tracks then pressurize you r tires to 5 psi and you should be good make sure you have 2-3" of clearance bewteen you tracks and middle tire when the machine is jacked up in to the air if too much your tires could slip and too little puts a strain on your axles.
