I have a ARGO 6X6 with a 436cc 2-stroke Kohler. It cranks over fast but won't start, even using starting fluid! Compression is around 155psi in each of the 2 cylinders. It has strong spark. Assuming the compression is acceptable, I'm guessing the ignition timing is off.
Here's the information I am looking for:
1. What year is it?
2. What kind of compression should I have?
3. How do you adjust the ignition timing?
4. What oil to fuel ratio should I mix (20:1 seems like an pretty smokey ratio)?
Here's the information I have:
Engine: Model # K.440-2T, Serial # B 29347, Spec # 38.003.10
Body: Serial # (on center of dash) 164 6, There is a decal on the nose that says 'ODG'.
Any help someone could provide me would be greaty appriciated!!!
1. What year is it?
