Can someone tell me the hottest I should be running before cooling off? Went for a drive today in deep snow and worried most of the time that I was pushing to hard.I have no low range because I'm trying to get a little playtime in before I rebuild the tranny in the spring. My argo dealer tells me it's a couple of tiny brass spacers need replaced on each side of a gear.Back to the temp. I was running about 230 deg. Still had fun though.
Oil Temperature?
I don't know your answer , but here is a link to an oil additive made to reduce oil temps. Two2cool Lubricants & Coolants
Thanks guys. As you know I'm new at this, so I only assume that there is a perfect answer for everything.I guess overall I think I'm just looking for a comfort level here.I'm a black or white kinda guy i guess.18 hp 8x8 with tracks and only high range breaking trail in deep snow prob. not the smartest thing to be doing anyway.
Buy the way,shouldn't there be vents in the shroud by my knees for the rotor blower for air flow?
If you are breezing around in the SNOW, then the outside air temp should be cold enough that you shouldn't even come close to an overheat situation. Plus that carb is drawing that same cold air through the cylinder/s which also helps alittle. Make sure you are getting plenty of fresh (Outside) air into the engine compartment, and that the body intake vents/screens aren't clogged. My Harley, which is air cooled, will normally run at just under 200 degrees on the hottest summer days.It's all just nuts and bolts.
OILTEMP
HI ,
Look after your oil it looks after the engine
why
ALL oil breaks down when operating over 212f the difference is some quicker than others [includes synthetics ]
Eg the the small block v twin kohler engine will eventually at some point in its life have heat related issues
oil leaks ,seals have gone hard
-case distortion has caused leakage past a gasket
inlet manifold vacumn leaks
-to much distortion in v block pulls on the bolts
cylinder head gasket
- blown
Over temp destroys the oil then u have cam and lifter wear issues
[the cams are soft from factory ]
These are just a few examples of what over temp does to an engine in the long term and other brands would have similar issues as well
Fit a med to large oil cooler with fan
The sump capacity is considered small ,needs to be bigger than 2 quarts on v twins etc
tomo
Thanks for the replies on this guy's, we had some really deep snow the year I posted this. My tranny still has issues in low gear,not from lack of trying though. If we get alot of snow this year the engine will be working hard again being in high gear all of the time. Low gear works as long as I use very little throttle, I'm sure a porqupine could pass me.My argo has 670 hrs and has a kohler 18 magnum opposing. Tomo, do you think a cooler would work on this? If so how much $ are we talking. I like your idea, summer driving may be in order
hi
I am not familiar with the flat/opposed kohler . The engine needs to be a full pressurised lube system for a cooler to work .
If u are looking for a cooler do a search either oil cooler or tomo and u will find the link.
Fix your transmission .All the metal particles in the oil will only be causing u more serious damage in other parts of your trans ..
tomo
You know, I've often wondered about the possibility of installing an low pressure low volume electric oil pump (if there is such a thing to be found
), plumb it into the drain, route the output through a filter , then a cooler with electric fan then back into the engine via the fill tube or other suitable orifice. Install a warning light and toggle or temp activated switch and you now have a cooler and filtered oil, even on a "splash" system. Would this work?
Might even work on a transmission. I like the warning light/toggle idea, because it would speed up oil changes!
hope that this helps you
