Altanater problums
Altanater problums
Hay guys I have a 2000 conquest the altanater has gone out has any one ever changed one and if so what is the easest way to do it with out spliting the tub our any thing like that i need some imput please help thanks skip PS can i remove the rad to make it easer to get to
Tags: None
i have pulled the rad on my conquest, the only part i found a bit tricky was getting the seal(between the rad and the left side shroud) back in place. it does open up quite abit, if you pull out the seal first, then undo the 4 bolts holding the rad and fan shroud, and drain the coolant and pull the rad hoses,(you might want to take the lower rad hose of the rad and waterpump). when you get to the alt. could you send some pics of the wiring and mounting. i am looking at trying to put one onto mine. thanks
hope this helps you out
DarinLast edited by dgh110; 02-22-2009, 01:01 PM.mud and ice
