roll bars
  • roll bars
    can you put roll bars on any argo or do they only go on some.Have a friend that can make them for me he make his own race cars but not sure if it can be bolted to the rail of the tub or should it go to the frame
    never will ride anything with less then 6 wheels again
    roll bar
    my very frist argo had 1 and it was bolted to the rail of the tub. my new 1 dosent have 1 yet, YET lol
      ok thank you .I thinkk I am going to put ot on the tub.I have seen alot on the tub but my friend was asking me what every one was doing tub or frame
        Angle Iron Band
        Another thing to do is get some angle iron(1 1/4" works for attex, not sure on argo)and go around the whole tub at the seam. Then you can work off that with roll bars and brush guards. Or I have seen the angle just on the sides to which would be alot easier to build.
          would this be anouth for a push baar and a wench>would it be stonge anouth
            I believe so, but I havent done it so............Maybe someone else who has can help.
              sound great thank you larry .I will let you know how it turns out
                Roll Bar/ Winch Support
                On my argo I used 1 1/2 angle on sides and it has held up to a couple of trees hitting the top with no problems on the side. On my winch and bumper I added a internal brace from frame up to seam to help with the abuse. I have a 4000 # winch and have pulled a argo and meat trailer out at the same time with no problems. My bumper is made of pipe and attaches to rim and plate and I have gone over some good size trees with it and have only bent a corner(tabs need to be longer) to keep from bending.
                I hope this helps E-K-C
                  could you mybe take some pictures for me. For I have some thing to go buy if you don't mind
                    a roll bar
                    Sweetgaddy-Your profile is a bit empty. I get that the rollbar is for an Argo. If it happens to be a conquest or any 8 wheeler,you should look up postings by Rock Doctor. His goes all the way around ,includes a good pushbar and winch and storage and rear protection in the back. He has made postings that describes how he made the bends and what angle iron he used. He has posted lots of pictures and many movies and he has more experience tham most of us. good luck
                      If you wanted a winch, I would buy the winch mounting bracing from Argo. It will tie your winch into the frame. The winch and mounting bracket from Argo can be pricey so I just bought the bracing from Argo and bought a winch from Cabelas and had a mounting bracket made.
