Whats up guys, been a while. Put a plow on my machine, used it three or four times in late december early january, washed up the machine and parked it mid january. Went out to start it tonight fired right up, put it in low gear just to put around the yard, idled fine, accelerated fine, then when peak out in rpms (for just a second, have a small yard) it just started gushing white smoke, looked like i was out fogging for mosquitos.
Anyways, figured id just give it a quick tune up to make sure it wasn't something simple, changed oil/filter, spark plugs, checked airfilter it was fine (replaced it 20 hours ago), replaced fuel filter and a cracking fuel line, went out hopin for the best and had the same results.
I'm out of ideas, the plugs were very wet and very black when I pulled out the old ones, I did have an occurence over last summer when I actually fouled out a plug so I am thinking it is getting more fuel than it needs. Would that cause the white smoke and is it as simple as a carb adjustment, or do i need to rejet, or what would all you engine guru's do?
Thanks!
Thanks!
