Hello!!
This is my first post since joining a few weeks back. I recently purchased a 2001 Conquest and am in the process of replacing a couple of bad bearings. Had outer one busted on the right hand idler shaft so I placed new bearings and flanges on it this weekend. Also had a busted outer bearing and outer flange on the front mid-axle on the same side. Had to order another bearing and inner flange for it today so I hope to get it back in shape this coming weekend.
Now for my other problem......it will not shift gears while the engine is running. It shifts very smoothly when I turn it off. I checked the operation of the clutches with the firewall removed and engine running and the secondary clutch on the transmission spins even with the engine idled as low as it will go. It appears that the primary clutch is keeping too much tension on the belt causing it to spin the secondary clutch.
Rock Doctor, any suggestions on what I need to look for or what I need to adjust and how to do it?
Thanks for the help!
JKL
JKL
......exactly.
