Hello Everyone,
My name is Mike and I have been lurking this site for sometime. Here's he story.
OK, so I just picked up an ailing Argo 6x6. I would like to find some info on it if possible. I don't even know the year. (Owner said it may be a 1987) It has a Kohler 440 2 cycle engine. And the plate on the dash reads. "k40003" What other info do I need and were would it be located? Are there owners/service manuals available online?
The unit needs a drive belt and after that point I can find out what else. The previous owner "Says" he has one on order. If not I will need to locate the proper one. He did start it while I was there, He may have had it all doctored up with starting fluid as when I got it home it would not start. I got it to turn over a few times but it would turn just a few then slip and grind. Rinse Repeat. Then it got to the point that all I could hear was the starter kicking out and not turning. Would this be indicative of a bad starter? Or perhaps a low battery? I thought about pulling the starter off but I had absolutely know Idea how to get to it!!! How is work generally done on these? Do you pull the body apart somehow? Contortion yourself awkwardly? Hire a troll to climb in?
The unit could definitely use rewired so a wiring diagram would be awesome!
This is just the beginning of what I am sure will be a long list of questions.
P.S. at $2500 for the unit, some tracks and 6 spare (used but decent shape) tires did I get reamed?
Thanks in advance! I look forward to being a part of this community!!!
if so, charge the battery slowly.might just need a charge up.?
charge battery, that doesn't work, then it's probably the starter, or a bad connection.........
