Avenger reliability
  • Avenger reliability
    The avenger has been around for a few years now just woundering how they are working out for there owners? any problems they may of had etc.
    Two years and O problems. Mine is efi and i would never switch back to carb...I do grease the outer bearings every second time in water. I also use Redline synthetic motor oil on all chains except the drive chains there i use Belray..
    Tracmaster
      Still running great. Changed out the front two chain tensors to the new style with larger teeth. Only thing that i have done. 2006 Avenger
        From what I've seen so far, ODG seems to have worked most of the bugs out. The earlier models had a few issues with chain tensioners causing bearing damage, and Trans issues (Undersized retainer ring). Most other issues I have seen were in industrial use (abuse), overloaded, and attitudes like "I don't own a bolt in it".
        For the rest, they are holding out great.
          Pretty much the way i see it too Rock.
            Hey Steve, I remember there was a thread about the transmission issues that the Avengers have here:
            Other than that, I really can't say for sure since I don't own one......I just wanted to bring that thread to your attention. Maybe more folks that own them can chime in and help you out. The great thing about 6x6World is the wide variety of machines on this site and all of the helpful folks that are always happy to assist you with making a good decision when it comes to anything related to an AATV compared to certain other places on the net that would rather make money off of you and never be there again to help once they got your cash. Good luck with the decision and let us know how it works out for you.
