I have a fiberglass top on my argo and now i am dealing with lots of engin noise inside the cab. has any one come up with a fix to deaden the noise? I am thinking of dyna matting the fire wall and seeing if that help. Any one else have any suggestions?
engin noise
OuchOriginally posted by M.A.S.H.907 View Postman i really like this site lots of good technical advise but so far. you all suck for answering post related to questions. this site has a plethera of knawledge froma ll the owners out there. Try shareing some.
you are the first person I'd seen on the site that has a fglass top. Maybe the top manufacturer has a sound proof kit. The tractor cab manufacturers have optional sound kits. Sound proofing is a science in itself. If you have an Argo you have gear wine and engine noise and too many holes between the engine space and passenger compartment.
To kill the noise you have to absorb the ambient noise, plug all the holes and decouple the vibration transferred to the structure. Dynamat helps to decouple the vibration but does little for the ambient noise. You need acoustic foam for that. Line the cab with the foam put the mat on the bulkhead and dash and make filler pieces for the holes and gaps.
I have a Bigfoot and I would probably upgrade the transmission to the latest version to kill the bulk of the gear noise.Acta non verba
I am guessing from your name you are from Alaska and I bet your top was made by Plaschem supply on spar ave. You might call Randy there and see if he has any suggestions. they made the tops for the argo dealer here in Anchorage. Good luck
Mark
its got a 32hp kohler liquid cooled EFIOriginally posted by eightwheeler View PostOk, ill tell ya then, rip that 2 stroke out of it and put in a nice 20+hp 4 stroke in it, that will fix alot of problems for ya, not just the noise
Any time you cover the body you start hearing all the noises from the drivetrain. The old conquest with the fiberglass tops were painfull to spend any time in. I've seen covered firewalls ect but the best way Iv found is noise canceling headphones.
