Stupid question, where is the adjustment for the idle on the 23hp Vanguard in my Frontier? Once the motor run a little hot I have a hard time putting it in reverse, it grinds. If it sits idling for 4-5 minutes then there's no problem. I'm assuming it might be idling a little to fast. If that doesn't solve it I'll bring it to the dealer for some adjustments.
Thanks
Thanks
With the body on my Max, it was hard to find but on mine it is under the air cleaner right where the arrow is. You kinda have to push the rubber back a little to find it.
. I look around in the tub, no, they stayed somewhere in the engine. I can hear them rattle in the shroud when I shake it.
I took the air filter assembly off and the idle screw was alot easier to get at. I turned it almost a fill turn counter clockwise and feathered the throttle a couple of times and sure enough low idle. It was a little too low initially but I used the voltage meter on the machine to tweek it in. Once the voltage levelled off at 14v it was tunned in perfect. No more grinding and I can change gears with out cursing. It has been cold hear the last week and I have no stalling issues...
Later.
