Ok, besides replacing a bent axle, we usually replace an axle because the Argo seals have worn a grove(s) in the axle causing excessive leakage. Well I found a fairly inexpensive repair. The Argo dealers may not like this, however there are 2 products which are used industry wide to extend the life of an axle many times.
The 2 products are called "Speedi-Sleeves" and "Redi-Sleeves", these are precision stainless steel sleeves which are installed over the grooves for a permanent repair. They cost around $35.00 for a 1 1/4" axle, attached are a couple of links that explain the products.
http://www.skfmarcomms.co.uk/focus/i...edi-Sleeve.pdf
what tracmaster said.
