Have any of you guys tried putting the newer style axles, with the smaller inner brngs, into an older Argo with the straight shaft axles?
I have about a half dozen of the newer style axles kicking around the shop at home, and an older 6x6 with the older straight axle shafts. I figure that I should just be able to swap the older axles with the newer style. I won't be able to change out the 2 front axles, as they are longer, and have the sprocket keyed to the shaft, but I should be able to change out the back 4
