What Is A Good Sealer To Stop The Water From Getting Past The Black Rubber That Is Around The Middle Of The Machine. What Is The Best Grease Chainsand Bearings .i Spend A Lot Of Time In The Water .thank You For Any Imput
To Much Water
if u are looking a calk use 3m 5200 is about the onily one that is approved for below the water line in boats . but be weare it is not used to take on and off also u might want to look at byrtel rubber . it perment too . robbieOriginally posted by nickles View PostWhat Is A Good Sealer To Stop The Water From Getting Past The Black Rubber That Is Around The Middle Of The Machine. What Is The Best Grease Chainsand Bearings .i Spend A Lot Of Time In The Water .thank You For Any Imput1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )
R.I.P sage rogers 4 11 09 .
