What are the part numbers for bearings/seals? 99 argo response
  • #16
    Originally posted by smog View Post
    my 1987 conquest NKB also have the 1ΒΌ" inner bearings; the UCx05-16 are for 1" shafts... no go for my 8x8
    just a FYI (sorry if you already know this) that last number means how many 16ths of an inch inside diameter. for example the "-16" means 16/16th's of an inch which = 1 inch. the "-20" outter bearings mean 20/16's of an inch = 1.25" inside diameter.
    john
    • #17
      Bearings
      Bloodvette,
      I am doing a complete rebuild and need all bearings. I would be interested in the suppliers name also. Thanks Tim
      • #18
        john
        it's ok, it's just that I wasn't expecting a straight shaft, as per all parts numbers flying around, I was looking for UC206-20 outer and UCX05-16 inner. but It's clearly not what I need.
        • #19
          John,
          did you find your bearings in Canada ?
          if so, please tell us your source.
          thank you
          Smog
          Montreal, Canada
          smog, I spoke with the guy today. he said your price is around $8 for the UC206-20. keep in mind this is an offshore bearing. however I did install one the other day and had to put the die grinder to elongate the grease track. you'll see what i mean if you order one. the actual argo bearing has the grease port (through the outter race) in the approriate place and the offshore is not quite perfect. I verified grease coming from the bearing seal after a few pumps so I'm confident. the company is BDI canada but don't quote me on the price. It should be aorund $8 ea. BDI canada is all over canada so you may have one in montreal. just checked- LaSalle.
          • #20
            I have been purchasing bearings for my AATV's from Baum Hydraulics Corp, they sell domestic and imported bearings at reasonable prices. They also offer qty discounts. Baum Hydraulics Corp
            I just rebearing my older Max4 With greasable bearings and was able to get heavy duty US made stamped flanges with grease fittings that are .045" thicker than the original. The heavy flanges can be torqued down more without distorting.
            Acta non verba
            • #21
              part numbers and prices
              for my 1987 conquest NKB serial :
              inner and outer bearings are UC206-20 paid 5.64$us at SASBearings.com
              paid 2$ for the small seal from argo
              paid 7.60$canadians for a bigger double lip spring loaded seal timken 471737
              and 10.80$canadians per foot of 50-2 hitachi chain from japan
