2005 argo bigfoot- help
  • 2005 argo bigfoot- help
    I just bought a second hand 2005 argo Bigfoot. It keeps pulling to the left. The brake on the left gets hot and sticks on. I have to wait for it to cool down before it can work again. Please give me advise on what to do.
    Thanks
    Roland Meadus
    Did you try to bleed your brakes.
      yes i did i bleed both and it didn't make any difference.
      thank you
        you may have a brake pad dragging, the master cylinders actuating rod may be over adjusted, or the caliper pistons sticking. If you have some slack when you pull on the brake lateral the problem is probably a caliper piston hanging. The calipers are easy to remove to check. If you don't have a parts manual call Argo they can help you out.
        Acta non verba
          someone might have pot dot 3 fluid instead of dot 5 i think. my friends did the same thing. when it got hot the breaks looked up and he had to let them cool down. just a though.
          support your local search and rescue unit and get lost.
            I took off both caliber .I used a c clamp to push the piston in then i pump out the piston again . I tried this a flew time it didn't look like there was any trouble with this.I put it back together clean up the caliber everything was the same
            thank you
            rmeadus
              Confirm that the master cylinder plunger is returning all the way. if the plunger gets hung up the caliper pistons will not be allowed to relax fully.
              Acta non verba
                Is your fan on,,,Blowing on your Brakes,,,,make sure the hose is hooked up and blowing on them also( Just a thought,,I found my blower hose off/disconnected).
                Look into the Idler shaft bearings, on that side,,,(and all of them),,, also give the Idler chains a wiggle, with the brakes off,,,the brakes hold the disk from flopping if there is a tranny/bearing problem,,,Just what I have run into on my 2000 BigFoot !,,,,,AHHHHH into the Belly of the Beast,,,have plenty of rags,,,,one Greasy place to play,,,LOL.
                PS,,, WD-40 works great as a hand cleaner !! Use it all the time cuts the grease quick,,,easy on the skin !!
                  thank you
                  rmeadus
                  Ok then i would have a look at the master, take your firewall cover off and remove the push pin so you can take the rubber boot off that covers the plunger, then reinstall the push pin and pull down on the lever,return it up and see what the plunger is doing, try it a few times and if the plunger does not follow the push pin you may have a bad spring in the master cylinder, but i would buy the rebulid kit, they are cheap and would make sure nothin else was bad was reinstalled
                  "Argo 8x8's only" type of guy
                  "old school Argo expert"
