the flaw with the argo tranny is the open differential unit.
sooooooo what about putting a solid shaft with 2 end sprockets we can engage on the chains whenever we need fully synchronised traction. I talking about a simple straight shaft mounted on 2 arms bolted to the chassis rails we can push down on the chains. No need for fancy bearings, simple bronze bushings on the straight shaft should be enough. straight keyed shafts and sprockets are cheap and a foot lever to force the sprockets on the chains is easy to figure out. the other option I have is to use the splined ends on the 8x8 nkb argo shafts. I have 1 inch of splines available to put a shaft and sliding splines sleeves to lock the 2 sides together if needed.
keep in mind the systems are "on demand" only.
let me know your idea on it; the argo is dismantled to redo ALL bearings seals and chains so now is the time to upgrade some features.
And safety switches so both sticks have to be against the firewall for the button to work. What the button does is undecided, electrical magnetic clutch, maybe other. It wouldn't have to lock hard, maybe just a limited slip. That's been my thoughts/dreams. Not simple though.
