Does anybody know of the Spirol coiled spring pin part# that is sold to to Argo as their part #11145 pin?
I'm hesitant to buy a pin until I know what the shear strength is I want, and I'm thinking that Spirol may make a custom coil spring for the older Argo applications.
Argo wants $2 for each pin, but I can buy a 500 pack from Spirol (Part code CLDP .312X2.500 MBK) for only $125.79, assuming the standard pin is what Argo used. That works out to a tad over 25 cents a pin.
Hmmm....I wonder how long it would take me to break 500 pins?
I've also found them at Grainger (Item #5EB84), assuming I'd want the standard-duty pins with a double pin shear strength of 8,700 psi. Those pins are available in a pack of 25 for only $17.08. That's less than 69 cents a pin. More money per pin, plus I'd lose the "cool factor" of having a bag of 500 shear pins for my mid-80's Argo.
No...I don't want to to to bolts. I just stripped down my second mid-80's Argo where the previous owner put bolts instead of pins on every sprocket, and can tell you all for a FACT that if you run bolts you will elongate your sprockets a lot more than if you use Spirol coil spring pins. In addition, you're going to eventually bust something. This rig had a broken idler shaft.
Here's why I'm not a fan of putting in bolts. A 5/16 grade 5 bolt has a tensile strength of 120,000 psi. Shear isn't published as an ASM standard for bolts, but the recommended calculation for shear is 60% of tensile. That gives you a shear strength of a grade 5 bolt of 72,000 psi, roughly nine times the shear of a similar coil spring pin!
Kind of gets you thinking it may pay to stick with pins.
Thanks guys...
Bob
Thanks guys...
Bob
