I have the argo in the garage. I took off the air cleaner and removed the carburetor. Unscrewed the fuel solenoid and used a flat head screw driver to pull out the main jet, per the service manual. Its about the size of a small screw, made of brass. It is stamped 104 on the top by the flat head screw slot. Isn't 104 even smaller than the sizes you were suggesting, meaning it should run even better at very high altitude?
Conquest carb jetting
The dealer in Colorado had written in sharpie on my clutch shroud that my machine had a 104 in it, but when I pulled it out it was a 108. Yes, the 104 is the ultra-high altitude jet for that engine, but in talking with the dealership about it they told me that they made some of the engines a bit too lean, which can lead to temperature issues (too hot ) or fuel starved condition. It is better too be a little rich than too lean. I would try a 108.
Pull the spark plugs out and see what color the burn on the ends are.
Why you have that off you should remove you valve covers and make sure you have not thrown a rod. They are easy to take off/on.
Does your solenoid pin move freely?
104, yep that's smaller. If it ran at 8K with jet 104 it will only run better at 11k. At 8k you probably want to monitor for running too lean.
Replace the after-fire solenoid with a bolt.
And, as thorn has mentioned, check the push rods.
After that we'll check ignition. You can pick up a spark checker at harbor freight for something like $4.
are we SURE that replacing the solenoid with a bolt will have no ill effects? sounded like some people had some doubts... What's the benefit exactly?
here are some photos of my push rods etc
I can't really tell if they are straight or bent or what. hard to see them. Here is the "front" cylinder facing the front of the argo
Here is the back one, closest to the cab/windshield.
how do I know if its running too lean? what are the symptoms? It idles and seems to run much better at 8k. At 11k it didn't idle right, kept sputtering out. could not get rpm's low enough to switch gears without it killing.Originally posted by JohnF View Post104, yep that's smaller. If it ran at 8K with jet 104 it will only run better at 11k. At 8k you probably want to monitor for running too lean.
yeah, solenoid pin moves freely.Originally posted by thorn View PostThe dealer in Colorado had written in sharpie on my clutch shroud that my machine had a 104 in it, but when I pulled it out it was a 108. Yes, the 104 is the ultra-high altitude jet for that engine, but in talking with the dealership about it they told me that they made some of the engines a bit too lean, which can lead to temperature issues (too hot ) or fuel starved condition. It is better too be a little rich than too lean. I would try a 108.
here is spark plug from front cylinder
When I took off my valve covers, 1 pushrod was off of the rocker. The reason was a very tight valve that the spring tension couldn't overcome and resulted in the pushrod falling out of place. it wasn't bent, but the valve was hanging open a little and my engine had very low power. Depending on how old that spark plug is, the black residue looks like a bit of oil and since the electrode and electrode porcelain are so clean, I'd say it's been lean and maybe running a little hot because of being lean. A proper fuel ratio should show up on a spark plug with sort of a gray or brown color on the porcelain. I'd also double check that the correct spark plugs are in your engine, wrong heat range can cause issues too.
The solenoid's actual name is anti-afterfire solenoid. Its purpose is to stop the flow of fuel at the same time that ignition is turned off so that the inertia of the engine doesn't pull fuel/air through the engine as rotation stops and result in an afterfire. You probably won't experience an afterfire anyway but you an mitigate by letting the engine idle and cool a minute or so. Besides, afterfires don't hurt anything.
See THIS EXPLAINATION. (the solenoid purpose fits in the delayed ignition category)
And yeah, I know the pin moves freely. Until it doesn't and plugs you up. When that happens flip the choke on and take your time until you get to the tools and replace the solenoid with a bolt. (or do the snip). (bolt's cleaner
The spark plug doesn't look all that bad. Maybe a bit lean. Might need the 106 for 8K. (I knew Argo was being conservative with their jetting but didn't have the time to do the experimentation.)
But my reading: The base ring has soot that I would guess means that idle is too rich. The insulator is off white and the electrode doesn't look too rounded so at higher than low idle (the high idle circuit of the carburetor - it has two circuits) it is running somewhere pretty close to where we we want. Do google "reading spark plugs" though as this is not my science.
Your pushrods look good. Like PaSean said, when they are bent they fall out from under the rocker.
You probably need to adjust low idle mixture at higher elevation and you probably need to look at your clutch tuning.
I would do a few things first, maybe you have already?
compression test + leakdown test
confirm output of fuel pump (within spec)
If these prove to be okay, I would move on with confidence.
Also, does your machine seem to use any oil or do you notice black smoke under heavy load?
FYI-I would try to avoid backfires on shutdown.
engine does look clean. the guy seemed like he maintained it well enough.Originally posted by philipatmaxfour View Post
This is an educational thread. My guess is black and sooty means running too rich. Were you at highest altitude when you last shut it off?
Pushrods have not slipped out and do not look bent. Engine sure looks clean.
last shut it off at 8,000ft.
1. do I need special equipment to do a compression test?Originally posted by Buzz View PostI would do a few things first, maybe you have already?
2. how do I check fuel output?
does not seem to use oil and have not noticed any black smoke.
ok. sounds good. I will plug her up. heheOriginally posted by JohnF View PostThe solenoid's actual name is anti-afterfire solenoid. Its purpose is to stop the flow of fuel at the same time that ignition is turned off so that the inertia of the engine doesn't pull fuel/air through the engine as rotation stops and result in an afterfire. You probably won't experience an afterfire anyway but you an mitigate by letting the engine idle and cool a minute or so. Besides, afterfires don't hurt anything.
idle is great at 8k, just not 11k.
Put the plug in the fuel solenoid. Put everything back together.Originally posted by ARGOJIM View PostBlue try to start the engine, let it warm up some. shut it off and unplug front spark plug wire if it starts and runs that cylinder is firing, shut it off and replace wire and remove rear wire see if it starts and runs.
Or you could remove the valve covers and visually look at the push rods/rocker arms and see if one is off.
The Kaw's don't run that noticeably bad when running on one cylinder except under load
It sounds as if it either has thrown a push rod or the fuel solenoid is sticking partially closed ( which would make the jet intake smaller than it is) as Thorn wrote.
warmed up engine. unplugged front spark plug wire, tried to start engine. would not start.
plugged back in, started up.
unplugged back spark plug, started up.
unplugged front again, would not start.
maybe I am running on one cylinder? Both sets of exhaust pipes are hot when running (with both sparks plugged in)Last edited by Mike; 01-29-2015, 09:43 PM. Reason: merged three consecutive posts (you can reply to everyone at once by using the multi-quote button)
for a compression test you'll need a compression tester. You will crank the engine to obtain a reading. (warmed up engine)
for a leakdown test you'll need a leakdown tester. Instead of cranking the engine, you'll instead use an air supply attached to the tester to pressurize the cylinder and note your percentage of leakage. It will tell you more about where the leakage is taking place (if present)...intake/exhaust valves or piston rings. Also done on a warmed up engine one cyclinder at a time and with the cylinder @ top dead center. Like the compression tester, the leakdown tester is screwed in place of a removed spark plug.
Look up the specs on your fuel pump. Then you want to catch the fuel from the pump over a designated period of time and measure the volume produced. You'll have to look that up to see that it is within specs. Electric pumps just need voltage (usually just the ignition powered on). Mechanical pumps will need your engine cranked at normal cranking speed for a certain length of time. Again, you'll have to look that up.
Look up a couple videos on youtube to help you along. Also make sure your choke isn't closed or partially closed when you don't want/need it. Might be worth checking from end to end (quick and easy).
by the way, twice now (once at 11k, once at 8k) I have noticed underpowered performance (difficulty turning or moving) and then suddenly I have a momentary boost, usually right after I changed gears. Maybe one of the cylinders is kicking on and off?
your ignition coils can most certainly be an intermittent problem. That's where it's frustrating, because even if you confirm spark with the hood off, it can still happen when you go to drive the machine. Forgot to ask, how many hours on your engine?
350 hoursOriginally posted by Buzz View Postyour ignition coils can most certainly be an intermittent problem. That's where it's frustrating, because even if you confirm spark with the hood off, it can still happen when you go to drive the machine. Forgot to ask, how many hours on your engine?
