I finally got my 89 Magnum 8X8 out for a major run and had a great time
. It pulled a very heavy trailer with no trouble and ran like a dream. What it did not do, at times, is stop
! In my mind when the brakes got hot I would lose all braking power on my left handle. If I let it sit for a few minutes the braking power would return?!?!. This fade in and fade out situation would happen every couple of miles. What's with this? Are there seals in the master cylinders that may need changing?
Also, my battery died on the way in. It is charging on my bench as I type and will be tested later. How can I test the charging system on the Argo? The machine ran despite the dead battery (pulled it to start) and ran very well. None of the accessories ran (lights, cigarette lighter, sump) and I assume this is because there was no battery power and too little engine power. Are the charging system and the power system to run the engine separate systems?
If the charging system proves to be bad, do I have to do anything other than install an alternator to keep the battery charged? Do I have to disable anything with the stock charging system?
Thanks for the help!
, if you run the machine without a battery hooked up, you should ba able to put a Volt Meter on the battery cables. If the volt meter read over 12 volts, it should be working. Did you do lots of winching by any chance? Charging systems are VERY slow on machines without an alternator. I have killed my battery numerous times due to winching. Even running the lights for extended periods can have an effect on your battery.
