I'm going through my new '98 conquest and cleaning everything up. I thought I might pull out the clutches and rebuild them in the manner suggested by Rock Doctor here.
I've looked at the service and parts manuals and see that there aren't too many parts that appear need replacing in a rebuild. Does anyone know if there are kits?
What would you replace? Springs, nylon buttons, bushings, keys, weights-blocks,... ?
RD - you mentioned that you were waiting for parts to do a rebuild, what did you replace?
Part #s 127-71 (driver clutch) 126-24 (driven clutch)
And it looks like the only spot to get lube is the cam area of the driven clutch, right?
I rub graphite all over the shoes and weights, everything that moves or slides. I think the stock spring might get weak with age, lowering the working engine rpm. RD's shim improves this and also improves downshifting.
(I'm at work).
