pre '99 tensioners
  • pre '99 tensioners
    Pulled out my chains to clean and lube them. I will probably be replacing some of them, but the reason for this post is to ask a bit about the chain tensioners.
    Has anyone here done something different? These appear to get torqued enough to bend them. I pulled then out and am bending them back but I don't expect that this is a long term solution.
    Swap the top and bottom pieces. Then the twist thats "worn" in them will be the opposite of what they were. Sometimes I add washers to space the set away from the frame, if needed. Replace any weak or stretched springs. One complete tensioner kit is about $30.
    I broke one once, tried to have it welded, it was like funky pot metal. I don't try to bend them any more. No need, as the above method works great for me.
      I like that! Let them bend themselves back. How long before you need to flip them again?
      Unhuh. Made me nervous to be bending them too much.
