I have a problem that comes and goes. my argo is a 99 Response. the right hand brake lever has more travel than the left one sometimes. basically, I have to push it farther down than the left one to activate the brake. so naturally I suspected air in the system, so I bled the system. I actually completely bled both sides and flushed new oil and topped it up. anyways, it still happens. but not all the time. often after running for a while, the levers both have the same travel. I looked in my manual, and referred to the adjustment section. this section mentions that you should verify that the piston is retracting fully when you release the lever... and thats where my problem lies. I'm referring to the cylindrical piston inside the master cylinder that pushes the brake fluid. It is not always fully retracting when I release the brake lever. is there an actual return spring inside? I'm suspecting it has broken. I haven't openned it up to have a look yet. just wondering if anyone has come across these symptoms before.
john
john
