I just bought a set of Argo tracks...used...for my 1999 Argo Conquest. I installed them and it was much easier than I thought but now I have a problem. I now have a flat tire on one of the inside wheels so I need to take the track off that side to fix it. Problem is I have ridden through a bunch of mud with the tracks on and now I can't find the link I used to put the track together and for the life of me I cannot get any of the others to come apart because I guess they are rusted on. I can get the hex nut out of some of them but cannot drive the pin out. I have dowsed them with wd40 and pounded at the pins and beat up my pin holding hand pretty good but none of them will move. Has anyone had this problem? Is there a way to get these pins to let go? I usually apply heat to release rusted bolts but can't see doing that with plastic tracks. Any suggestions would be appreciated.
In the event that I cannot get them off and the tire stays flat, can I just go with 6 good wheels on that side or will that be a problem in the snow?
