I just bought (New to me) a 2003 conquest. It has a Kawasaki 20HP in it. When I test drove it it would not run unless the choke was held on and even then it surges from full revs to stall then back up again.
I had the dealer rebuild the carb and it ran great when I picked it up. I put about 20 mins on it and now the problem has resurfaced. I do not want to go back to the dealer as I have no faith in their work as when i took off the Air Cleaner Cover the condition of the air cleaner was so terrible I suspect their attention to detail is non existent.
I suspected that as I had to run on full choke that there was a fuel delivery issues. I yanked the hose from the tank and ran a new one to fresh gas in a jerry can. The Fuel pump did not seem to demand much fuel in fact it barely sucked up the new fuel. It was making loud clicking noises when it ran dry though.
I figured I would swap out pumps but the replacement cost is almost $ 300.00 for tiny pump. Is there an after market suggestion? What sort of fuel line pressure should I be looking for? Could Old gas be the culprit for this condition?
Any help appreciated.
. Also chech your Float to see that it's not sticking.
