I have just purchased a Argo Response on eBay and was wondering what year it was manufactured. The serial number is RB 13689 and model number V896-65.
Also the drive chains from the transmission are very loose, the right hand one sometimes kinks over double and jams against the frame. Are the tension of these chains able to be altered and how much defllection should they have ?
I can't shift it into gear with the motor running, it just crunches. When it is idling in neutral the pulley on the transmission is spinning, is this how it should be perhaps the belt is too short ?
I can't see any oil level check on the transmission, how is this done ?
What size engine was originally in this machine ? It currently has a 13 hp chinese motor pull start. I have a 10 hp diesel electric start sitting in the shed, would it be too small. It would probably have similar grunt to the chinese motor.
Great forum and very informative, thanks for your help.
Paul
Paul
