93 Argo model S argo 6x6 Idler shaft bearings
  • 93 Argo model S argo 6x6 Idler shaft bearings
    Does anyone know what aftermarket bearing and number will cross over with the argo bearing #(101-30) for the idler shaft.
    Thank's
    Although i have a 91 8x8 magnum part # 101-29 required ,
    i've found a skf bearing/chain dealer with exact bearing replacement with manufacture p/n"s
    Kinecor Ltd in newfoundland ,canada uses this # printed on bearing/collar
    # is 1230-1-1/4ECG i assume you can use these as long as your diameter of shaft is 1 1/4 inches.
    maybe find a skf bearing dealer near you.
    prices were 16 dollars each as compared to argo dealer at 35 dollars
      Thank's for the help newfy8x8.Ill have to see if i have a skf bearing dealer around close or SAS bearing's might have this bearing i all ready read that the UC206-20 bearing would replace the 101-35 bearing for the axle's so maybe they'll have the 1230-1-1/4 ECG bearing.Really want know till i tear into it and see what i'm looking at. i'm planning on going through the whole thing.
