2009 6x6 Frontier has about 50hrs on it. I started hearing the chains slapping under the floor boards. I pulled the cover and discovered that the top of the chain has about 2 1/2 in of travel while the bottom ones are really tight (no travel). Tried pulling the glide block up as suggested in the manual with no effect. I can rotate the spring upward with my hand, but the block seem to be pinned under the bottom chain. The top chain is loose and slapping the frame. I've attached 2 images.
Can anyone tell me how to adjust and/or how it is supposed to be? Proud new Argo owner with "0" Argo/ATV experience. Thanks in advance!!
Mine is an older argo so I'm not sure on the chain tension er set up on the new ones but shouldn't there be a nylon guide on top of the chain as well? Maybe someone with the same machine will chime in here soon.
